Home › Forums › TRUCK BUILDS › My First Land Cruiser
- This topic has 310 replies, 9 voices, and was last updated 4 years ago by
March 10, 2020 at 2:30 am #209046
toys-n-yotasKeymasterIt seems like the LC team had a few objectives in mind when they made sure the frame rails lined up perfect for Steel Bumpers and winches.
Those sliders look wicked, a lot wider than I thought they were when mounted.
March 10, 2020 at 8:49 am #209052
Toy-YotaParticipantThanks guys! Yeah the winch tucked in there nicely, I might get a chance this evening to get bolted it down and test fit the bumper and fairlead.
Keep in mind though you could get an 80 series with a factory Toyota PTO winch so it seems like they designed the frames like that for a reason!
March 10, 2020 at 11:03 am #209057
toys-n-yotasKeymasterI love when form follows function, so logical.
March 11, 2020 at 8:56 am #209065
Toy-YotaParticipantTotal stealth mode. You can barely tell there’s a winch in there. Just gotta order up my synthetic rope and it’ll be all good to go. I wired it up yesterday and it works. I mount the control box under the hood. I’d like to find a better spot for it but the wires only go so far.
March 11, 2020 at 10:47 am #209072
Slick_YotaKeymasterIt looks good!
March 12, 2020 at 9:43 am #209075
Toy-YotaParticipantDoes anyone have any experience with synthetic winch line? Brand, thickness length etc?
March 12, 2020 at 12:41 pm #209076
Slick_YotaKeymasterI have steel cable on mine and was just going to use that until it wore out. Amazon seems to have some good deals – Ranger synthetic 3/8 x 85′, 20,500lbs for $99.
A bunch of guys on TacomaWorld use synthetic cable and I’ve seen it in action, but not sure what brands…
This reply was modified 5 years, 10 months ago by
Slick_Yota.
March 12, 2020 at 1:14 pm #209083
toys-n-yotasKeymasterThat is so stealth. I can’t spot it at all. Is you plate on a hinge?
March 12, 2020 at 2:15 pm #209084
Toy-YotaParticipantThat’s the one I was thinking of getting, I’d like to get a proper snatch block too mine is really heavy and big.
Tom it’s not on a hinge but I think that might be a good idea, or try to move it somewhere else. I haven’t really decided.My exhaust hangs down really low so I cut it and bolted it up a few inches higher. And I added a factory tow point to the back of my frame for a solid anchor point.
March 13, 2020 at 8:14 am #209091
Slick_YotaKeymasterI thought you might turn the exhaust to come out behind the tire – this would give you a little more clearance back towards the bumper.
Before I put my high clearance (at least higher than stock) I used to drag the bumper on everything…
March 13, 2020 at 8:40 am #209093
Toy-YotaParticipantThat was my plan actually but I didn’t have any welding wire and I’d like to keep the Borla resonator that’s on there. This was just a quick fix to get me going. I’d like to cut it above the rear axle and then do a side exit after the tire.
It just always bugs me when I see how low it is and with the size and wheelbase of 80, it’ll hit on any kind of ledge and probably get crushed
March 20, 2020 at 8:58 pm #209126
Toy-YotaParticipantI dont know why when I resize it they flip sideways but you’ll have to deal with it. Been messing around in the back 40, building a little cabin and wood stove. I got stuck and of course haven’t put any winch rope on yet so I had to get a tug from my from with his JK. Right now I need the winch rope, the truck needs new belts, and it needs a coolant flush and fill which I got the stuff for today
March 21, 2020 at 9:12 am #209132
toys-n-yotasKeymasterThat cabin looks wicked! Is that a natural rock formation for the back wall, or what remains of a 200-year old foundation?
Your sequence of photos reminded me of a Mitch Hedburg bit “If I ever get lost (stuck) in the forest, fuck it I’ll just build a house. Well I was lost, but now I live here. I have severely improved my predicament”.
How many tensioners and idlers are on the front of your motor?
March 21, 2020 at 9:32 am #209133
Slick_YotaKeymasterCool cabin!
March 23, 2020 at 2:41 pm #209139
Toy-YotaParticipantYeah it’s a natural rock wall, thanks guys! I believe there’s just a tensioner for the AC belt and then one tensioner for the alternator belt, which is actually double belted. I tightened it up and swapped some belts to get the squeaking to stop.
My synthetic line came in today too so gonna get that spooled on.
