My First Land Cruiser
Home Forums TRUCK BUILDS My First Land Cruiser
Viewing 15 posts - 211 through 225 (of 310 total)
  • #210330
    Good work on the Jeep!
    Does unburned jet fuel have any significant odour?
    #210333
    The odour isn’t as bad as diesel or kerosene. It leaves a little smell for sure but it heats up the shop quick so I usually have a door cracked open.
    Got a new toy today!
    #210335
    Plasma cutter! Nice!
    #210336
    Awesome new toy! I’ve got way more hours plasma cutting than welding under my belt, such a useful tool. Haha better keep it away from the Jet Fuel.
    #210340
    Hopefully it works out well. I have a few projects on the list. 1 and 2) front bumper for the LX and a stubby bumper for my friends JK. The next project might be another trailer, if mine sells. If it doesn’t I might build another anyway. Something similar in design but a little bit more lightweight.
    #210392
    Sweet projects!
    How do you plan to lighten your next trailer setup?
    #210402
    Definitely plan to lighten the next trailer. If I build another trailer I’ll probably do axle-less suspension. I’d also like to try to keep the atv in a low center of gravity, maybe making some spaces for the tires to sit in, to keep the atv low. The big tires on the trailer will give it the ground clearance it needs. I could also to try to French the suspension components up into the frame a bit. We’ll see how it goes, I’m not Going to build anything until mine sells. I won’t be upset to keep my trailer. I got new tires for my ATV. Pretty pumped
    Also I got the steel for my bumper yesterday and we’re gonna start the mock-up tomorrow
    • This reply was modified 5 years, 1 month ago by Toy-Yota.
    #210406
    Those are some meaty tires! Holy crap. I doubt my 250 could even turn those treads haha.
    Great ideas for lightening the next trailer (should current sell). I’ve never pulled a trailer offroad, would imagine it eats up a lot of power dragging that dead weight. The 4WD Action buys sure make it look easy eh?
    #210410
    Oh ya the tires are big, I love it.
    The trailer offroad isn’t too bad, in low range you can lug it around pretty good it just requires constant momentum. I’ve only taken them on a few tough obstacles but I’ve never had to winch.
    The trails are here are so tight in a lot of cases, that’s more the issue. I’ve been toying around with something enclosed vs open. I really would prefer another pop up. But a pop up with a space on the front or back for an atv makes it really long. I really want quick setup, setting up and taking down camp is never exciting for us. We either want to get to relaxing quick, or when we’re leaving, get it down quick!
    We’ll see what happens, I’m asking 5k for my tent and trailer which is basically what I have into the trailer plus a little bit. In my opinion that’s a good deal, I won’t want to sell it in the spring though, I won’t have enough time to build another once work starts back up.
    #210415
    I know nobody signed up for Jeep builds but here’s the start of the stubby bumper, it was the easiest of the two so we started with this. It still needs a fairlead cut into, and then we’ll cut the top out for a winch to sit in
    #210417
    LOL. Looks pretty heavy duty. What thickness of metal did you use?
    #210420
    We only used 1/8 probably should have used 3/16 for his but wanted to keep the weight down.
    #210423
    Here’s my review of the plasma: it cut great, super fast. You need to be sure you’re cutting straight up and down, rather than at an angle. You don’t touch the tip to the material, So it’s a little hard to free hand. On a long straight you need to have a guide clamped on. On a project like this with lots of cutting you’d go through so many cutting discs on a grinder, it’s nice not to have to change them out and get covered in dust. Not to mention discs can get expensive. It cut through 3/16 no problem that was my first test. And we cut off a mount on the Jeep frame that was 1/4” and again no issue. I like the machine itself is really small and light. We only used it on 220 so I can’t say how powerful it is on 110. This unit does both it just comes with an adapter. Overall I was really impressed it’ll cut a 30” long section of 1/8 in like 20 seconds. You do have to clean up some of the slag though after. So a little added time there. But for complex cuts and tight to reach places it’ll be great. It cut through a painted surface no problem too. If it lasts a few years of use I’d be really happy.
    #210428
    Jeep bumper turned out great! Simple and effective. I don’t mind watching Jeep builds, I just enjoy watching the fabrication!! Keep it coming Evan, looking forward to seeing your new front bumper for the LC.
    #210476
    Im trying to take my time with this one. Here’s my progress after about 7 hours, lots of measuring.
    Here’s what I’m going For, and here’s where I’m at. I decided to leave the winch plate separate, and I’ll bolt the actual bumper to the winch plate. If I need access to anything I just take off 6 bolts and then get right to the winch. Instead of dropping the whole big heavy thing.
    • This reply was modified 5 years ago by Toy-Yota.
