- This topic has 314 replies, 15 voices, and was last updated 2 months ago by
January 19, 2018 at 12:13 am #205879
NoeyParticipantGreens
January 19, 2018 at 12:18 am #205880
NoeyParticipantSouthwind
January 19, 2018 at 12:18 am #205881
Toy-YotaParticipantThose make me want to go wheeling! Awesome shots! Love the flop at Greens mountain with the J**ps in the background! Love watching people on that obstacle.
Ive only been there once, Indidnt really see where the trail goes after that. It seems to get really tight
January 19, 2018 at 12:28 am #205882
NoeyParticipantI managed to hit it twice in May 2017 for the first time and had great luck. Completed the trail without winching or carnage!
Ya you gotta continue past that obstacle to hit more action. Love the challenges and adrenaline rush! It loops back to where you start.
January 19, 2018 at 11:45 am #205883
Toy-YotaParticipantYou have a 4:1 case and 38s? How did you feel about crawling those obstacles with that ratio? Could you use a lower gear?
January 19, 2018 at 12:21 pm #205884
NoeyParticipantMy lowest crawl ratio is 80:1 and it works very well for technical stuff but coming off steep ledges I still gotta ride the brake at times. Also it’s too slow when trekkin through the smooth areas so I’m usually in 2nd or 3rd. At 100:1 I probably wouldn’t need to touch the brakes on those steep drop offs.
When climbing steep sections like where buddy flopped on Greens, I’m in 2nd gear at 43:1. It works well when I need momentum. The trick there is to get the tires smoking until they get sticky 😉
January 19, 2018 at 12:54 pm #205885Jason
ParticipantAwesome shots man.
January 19, 2018 at 1:38 pm #205886
NoeyParticipantThanks Jay! Miss wheeling with your old mini! But awesome overland action you have going on now! 🍻
January 19, 2018 at 1:56 pm #205887
Toy-YotaParticipantJason did you have that black 81 pickup?
Good tip Noey! I noticed that with a few Jks on that obstacle, you got to heat em up
January 20, 2018 at 3:08 pm #205896
Slick_YotaKeymaster@ Toy-Yota yeah, J had the 81. Made my truck look like a dinky toy!
January 20, 2018 at 5:19 pm #205907Jason
ParticipantYup I miss my first gen pick-up
January 21, 2018 at 12:27 am #205908
Toy-YotaParticipantI really did like that truck, any idea where it ended up?
Sometimes I think I should have bought it, I remember considering it when you had it up for sale. It was 22re swapped right?
January 21, 2018 at 7:44 am #205909Jason
ParticipantAdam has/had it. He use to be on the Sontt forum I think he’ has it out 2-3 times.
Yes it did have the 22re swap.
January 21, 2018 at 12:50 pm #205911BigRed
ParticipantGuys:
Great shots of your adventures. Our plan is to do some of the same. We are Eileen&Charlie. Picked up BigRed (2017 4Runner Trail) from Krezz mid last year and trying to enjoy every minute in preparation for our retirement.
Thought you may be able to help us with an issue given your technical abilities (mechanical wise).
Late last year when winter began, we noticed a growl/rumble coming from the drivers side front end. The sound was in sync with a vibration that we could feel in the steering wheel. Seemed to start with the cold weather and definitely gets worst when colder. It gets less noticeable as the truck drives for a while.
Thought it might be the tires, but same thing occurred after swapping stock tires for BFG T/A KO2’s.
Did some research and found similar discussions out there. Symptoms match our situation. Only thing I haven’t check is shifting to 4H to see if it disappears.
See following links.
https://www.tacomaworld.com/threads/vibration-in-cold-truck.306551/
http://www.toyota-4runner.org/5th-gen-t4rs/217741-2016-sr5-4wd-grind-moan-vibration.html
Was wondering if any of you have come across this and is it something I should take seriously. BigRed’s 16K checkup is due shortly and I will bring this up so it is on record at the dealership.
Any advice or insight anyone on the forum could provide would be greatly appreciated.
Eileen&Charlie
January 22, 2018 at 11:41 am #205912
Slick_YotaKeymasterWelcome BigRed!
Do you notice it get worse or go away when you turn one way or the other? Wheel bearings could show the signs you mentioned, but not if you’ve only got 16K on the runner.
Make sure you show the dealer exactly what it’s doing, so they don’t say “it’s fine, just bring it back if you notice it again”.
Don’t let them brush you off (my dealership didn’t like me at all 😀 )
