Viewing 15 posts - 286 through 300 (of 698 total)
  • #208691
    I will see you for sure on my travels this weekend.
    I received my ebay resistors from China in the mail many weeks earlier than expected.  I’ll tear the gauge cluster apart again and ask my buddy James to solder it up for me.
    I got 20 of those to my mailbox for $2.56.  That’s a dime for size reference.
    #208695
    Got a little work on the Power steering gearbox yesterday and today.  For the most part it was cleaning the grime and sludge off the exterior, then wire wheeling off surface rust.  Looks so good as is, thinking about just hitting it with some clear coat. But semi-gloss black is just as easy.
    I also rigged up a quick SST to mount the gearbox in my vice for the repair work.  I couldn’t crack loose any bolts without the vice, too dang tight.
    Before
    After
    Yesterday I also straightened one of the LCA alignment tabs.  A few of them will need some hammering and welding a strip to the exterior.
    #208704
    I sure hope my vice doesn’t fail under the boredom of waiting for me to proceed with disassembly.
    I made an attempt the other day, but got distracted and angered by the clutter of tools and crap on my work benches, so I cracked a beer and tidied instead.
    Planning to buy some powersteering fluid needed for assembly on Monday, and make some actual progress.
    Shout out to @finn for a pair of fenders from his viking hoarde!!  These are in great shape, and a little cleanup and rust prevention will keep these lookin’ perdy for years
    #208706
    Power steering fluid or ATF? What’s it say on the power steering cap?
    #208707
    Good catch Evan.  Throughout the manual it refers to coating everything in PS fluid, however the last step says to fill the reservoir with fluid “ATF DEXRON or DEXRON II”.    The Haynes manual called for the same fluid.
    So ATF is what I’m after, as soon as I get these V-belts get off.
    An upper rad hose, thermostat and gasket have been in my shopping cart a while, better order it up.  V-belt rubbing on upper hose.
    And failing thermostat gasket
    Gonna have some actual  physical progress today.  Excited.
    #208708
    The deeper you dig, more shit you’ll find. Still having fun though.
    Bought a $0.70 thermostat gasket, pull the old one out and find a large O-ring.  Wtf?  Both gasket and O-ring? More questions, must be time to continue digging.  My “Made in Taiwan” thermostat housing is not sitting flush to the intake manifold.  Held up a square to the mating surface, about 1.5-2mm gap, hence the double-gasket and still leaking. So a replacement housing is on order (tomorrow), about $30.
    Next. Tried to install the temp sender to rig up my oem gauges, looking for a thread adapter from 1/2” NPT chevy block, to M16x1.5 sender.  Ebay found me one for$38 after shipping from USA.  Annoyed I need a $38 fitting for the $6 sender I’m installing.  Locally I bought 1/2” NPT to 3/8” NPT for $4, but M16 vs 3/8 leaves a pretty loosey goosey fit. Not sure if thread sealant will suffice, but I’m willing to try.  Can always order the expensive adaptor should this fail.
    A fun day in the shop, despite actually fixing nothing.  Progress is great though 😀
    I made a great attempt to catch the coolant I knew would pour out, had two catch basins and a funnel.  Still 75% was caught by the concrete floor.
    Picking up my other V-belt and Upper Rad hose tomorrow, also will buy a tube of thread sealant and hope for the best.  Glob it on there really good.
    • This reply was modified 6 years, 1 month ago by toys-n-yotas.
    #208712
    glad to help tom. it’s crazy what can be found viking’s war chest eh?
    #208724
    The war chest coughed up some awesome stuff.  I’ll have to stick around longer next time, get an update on your LC and the 4Extra.
    I did the honourable thing today and bought a M16x1.5 tap on ebay today for $5.  Even IF I have to buy a 45/64th drill, and a 1/2” NPT plug, it’ll still work out cheaper than the ebay adaptor. Best case scenario I can tap a couple and sell them myself as a conversion piece for $15.
    RockAuto delivered the high-pressure power steering line today, so I gotta get it shortened and flared.  Really I’m out if excuses now to finish refurb on the steering gear. Perhaps while the girls at school tomorrow I’ll make some more progress.
    #208729
    Test
    #208754
    Test to see if this post has reached maximum…
    #208755
    Tom, apparently I can still post to your thread… but I can’t attach pictures either…
    #208761
    Webmaster
    Testing image uploads …
    testing image upload
    if you see the test image uploaded then this has been corrected.
    Happy New Year!
    Webmaster
    #208762
    upload away Tom!
    Guinness
    #208764
    Still no-go. Just lost another post with pictures.
    The “edit” and “Home” buttons are still present in the header too
    #208766
    Webmaster as toys-n-yotas for testing image uploads …
    same image as before
    seems to be working, not sure what to fix…
    Webmaster
