4307's Tacoma build
Home Forums TRUCK BUILDS 4307's Tacoma build
Viewing 2 posts - 31 through 32 (of 32 total)
  • #207163
    Toy-Yota
    Love me some trail gear shipments!
    Modding your steering shaft?
    My best friend has been looking for an actuator for his elocker for a year so he can finish his hi-pinion elocker with 5.29s: smart move on the cable actuator
    #207164
    4307
    The steering shaft doesn’t need any fabricated modifications, although I did replace the crappy roll pins that holds the slip shaft in the upper column together. The role pin sheared while wheeling a couple years ago causing play in the steering. A small tack weld replaced the role pin. The tack weld is small enough to shear if I have a front end impact during an accident, but strong enough to keep the steering tight and responsive.
    The Trailgear (Borgenson) parts are a direct bolt together system. I bought the Borgenson collapsable lower steering shaft separately a couple years ago. I bought the Trailgear U-joint to steering box part to replace the original Borgenson U-joint I bought before the Trailgear U-joint was available. The original joint would have required some modification to the splines in order to fit.
    My cable conversion came from https://www.chilkatdesigns.com/E-Locker.html
    Looking at the price of the kits may make you choke. But comparing the price of a new Toyota e-locker actuator, the Chilkat kit is great bang for the buck. IMO, the cable is WAY better and extremely reliable, simple design. I can also lock my rear in 2wd, locker you can’t do that without wiring mods.
A total of 208 users registered and the latest user is salisy, registered on 11-12-2025
