Home › Forums › TRUCK BUILDS › 03 Regular Cab V8 › Reply To: 03 Regular Cab V8
June 11, 2018 at 5:57 pm
#206719
Got the snorkel installed recently
Enlarged the hole for the flex tube, I could have probably clamped the wood in place and not drilled into the inner fender but I’m a professional hack,
test fitting
Eyeballing where everything should fit up
The 100 series (ebay landcruiser 100 series) snorkel fits like a glove, except for the radio antenna which is relocated inside the topper, still not wired up though
new u joint and carrier bearing
Made a new tool
dinged the nut
Got the spark plugs changed, used my new “workbench”
And then out of the blue, I realized I had a 9 led third brake light, so I wired it up
Headlights and windows finally clean
Almost there
